OK, here's the results
759 hp @ 7400 rpm
603 ft lbs @ 5800 rpm.
Best thing is no leaks and it didn't blow
WOW!
Those are some serious numbers. That should move your weight car down the track at an impressive rate.
7400 rpm = good flowing heads and not big CID
I am really surprised by the rpm (TQ & HP) with that cam.
Gaining that much power from the old 622 hp engine, should be worth almost 1 second in the 1/4 mile, and 1.5 from the 540 hp. You will feel that!
Look for some mid 9's
1993 Daytona, 5.50 at 130mph (1/8) 1.19 sixty ft (PG). Link to 572 B1 - Part 1
