Looks good Pete,....sitting up high in the tunnel like it should,...I notice your not running a 4 spd factory hump?....you'd gain a little more room around the tranny with it,....would really help with heat, as the Keisler when driven in OD mode for extended time periods puts off enough heat to fry Bacon and eggs on it
....you should put down some dynamat, the non adhesive foil kind, any adhesive, esp the tar type will only heat up and stink out your car
Pete,...did you ever get the 3rd gen shift tower from Richard at Keisler to upgrade?...as I see the Gen 1 in your pics
Mike
