I believe it. I bought the SS springs early in the deal , but they are nearly new and don't work with Cal Trac s according to what i have read. If I can't sort these out , I will probably go to a single leaf / Cal Trac set up. So........instead of helping , you are just rubbing salt in the wound. Thanks.
