Quote: Mike how much did you flatten the paint for the master cylinder and booster.I'm getting ready to paint mine. Thanks Greg
About 20% gloss I would say.
Would that be with DAR 9000 black and Ditzler flattening additive? Just curious as that is about what we have used in our shop, usually with hardener. You actually have to custom blend depending on particular part, environment (Humidity, temp, pressures, etc.) as even on a booth the outside conditions can effect the outcome at the extremes.
