gotta find a way to fit 225/60/15 tires. There are some good speed rated and touring tires in that size. What is the backspace/offset of those 15x6 Halibrands?
Do you have a rear sway bar to go with your Addco 1 1/8 front bar? Not as involved and swapping T-bars and not as expensive as shocks.
The backspacing is 4" for the front wheels. No rear bar yet. I'd like to go with the Firm Feel frame hung setup, but I'm not sure if it is compatible with the front bar I have. Guess I'll have to call them...
His rear bar will work fine with that front bar. The hotchkis and hellwigs are adjustable.
I have a 15x7 cop rim, 4.25 backspacing with 225/60/15 loose. A few cords sticking out of it. Those are close on some cars depending on alignment and prior body repairs. The 3 degrees of caster will help too because it move the wheel back a little.
The 4" backspacing usually hurts but the 6" wide might help.
