By better tires do you mean bigger, or actually better quality? I'm not sure I can fit much bigger in the wheel well without interference.
Both. And I doubt you are going to find good handling 205/65/15's. Gotta find a way to fit 225/60/15 tires. There are some good speed rated and touring tires in that size. What is the backspace/offset of those 15x6 Halibrands?
Sounds like the concensus (so far) is also better shocks and bigger t-bars. Guess I'll look into that.
Do you have a rear sway bar to go with your Addco 1 1/8 front bar? Not as involved and swapping T-bars and not as expensive as shocks.
Thanks for the offer to check out your parts ware house.
I'd love to take you up on that sometime, but right now I've got to try and get 2 sons back into school mode for tomorrow morning.
You should just drive the car. And see if it somewhere you want to go.
