What about the brackets holding the shifter up/ looks like one hard shift and thet would fold like a house of cards.
Correct you are.When the previuos owner mounted that shifter ,it had a bench seat in the car.On the last run i made in October ,i bent the "legs" of that shifter when i shifted it into high gear ,and it turned sideways.I am kinda ruff when it comes to shifting on a dragstrip (as a former 4 spd powershifter).I will be addressing that when i move the shifter back a bit.You certainly have a fine eye my freind ...
