I think that roll bar looks great for the time you had and it looks safe enough to me and I think it will pass tech for sure.
But I am going to say something just so others will have the info.
Rule book says the main hoop has to be attached to the "rocker sill". MOST tech's won't ding you on this. But, you want to keep the main hoop from pushing those 6X6 plates through the floorpan.
If you really wanted to make it safer you can add the 2 bars that would go to the top of your frame ties like was mentioned. I personally think it looks fine and will pass tech.
You are right on the plates to the sill thing ,and its hard to see in the pics but the outside edge of the plate is bent up a bit onto the sill.It isnt however as much as you did it.I wish i had done it like you did ,but at the time i was affraid (because i didnt know) ,that the bar needed to be centered pretty well on the plate.Looking at that pic of your ,i see that it doesnt have to be centered on the plate.Thanks for the compliment on the install ...
