Not about the bar but you might look at your shifter location again. Pretend your strapped in and see if you can reach up and get it out of park. I had this problem with my last shifter setup. I had to strrreeettttcchhhh when strapped in to take the car out of park, seemed perfectly fine until I put a harness in it.
Thanks ,and your right,It may very well be a problem with me strapped in the seat to reach the shifter in park.I will check that out.It shouldnt be too hard to move it back a little if it is... ![](/ubbthreads/images/graemlins/smile.gif)
