ATF+4 is a highly friction modified (HFM) fluid. It has more friction modifiers in the add pack than, say, Dexron fluids. IOW, the friction materials in the trans see it as "more slippery", as far as clutch engagement, etc. Always use the recommended ATF in modern transmissions.
