There has been a similar discussion on a GM based board about using the +4 in the GM 4L60E, and the same comment was made about it not being compatible in the older trans. Someone claimed to have fried theirs not too long after a switch to the +4. Amsoil synthetic was mentioned as the only synthetic compatible with the GM trans, but I don't know if its true or not.
