Originally Posted by 6PAX
I looked at the adjustment bolts on my other Dart and they are both about 1/8th-1/4" up into the slot on the lca at normal ride height.
Same torsion bars and weight on the front end and everything is not torqued ... LCA stud and upper cam bolts ?
I've always had to push the LCA down as far as it would go to get the Tbar in , the adjustment bolt is where it is at ride height ???
running up my post count some more .
