"With the suspension hanging down, bump stop removed, you need the adjustment arm to be as far down as possible.'.
That's how I originally did based on what I was told here. Being the adjuster bolts were sticking out of the bottom of the lcas (about 3/4") after I set the ride height it would seem to me the adjustment arm was down too low in the lca.
