I can't seem to get as comfortable with the Phillips Monitor as I was with the Acer color wise. Currently my Outlook 2019 mail looks like a 1955 television screen being a bit gray with horizontal lines. but at least it's not blinding me. I'm thinking the acer may have had more adjustments or options on the color but not 100% on that.
All I want is a 32" monitor that will support the dark mode in all the programs, browsers etc. I'm not into gaming or any of that. TIA
I'm not good with colors but this sounds pretty outrageous. All I can offer is you're not using the VGA input are you? I used VGA until a few years ago without much trouble until one of the 25 pins gets bent or damaged, then the colors are really really bad. If you using VGA, try a different cable. I've never had a problem with HDMI or Display Port. If you have the option of HDMI or Display Port, switch immediately.
