I made four spray bars for the intake valve springs...Only broke one this time around...Checked one of the others, and it still had full spring pressure, which I was not expecting. Hopefully these solve my valvetrain oiling issues, now I have a lower oiling issue as well. So I am going to use glyptall from Eastwood and do the whole inside of the block to help with oil drain back. After that, it needs an accumulator. I seem to go thru this every year...Looking forward to the day I do not have to pull the engine.
So smart cam guys, answer me this, how is it I am told the biggest hydraulic roller I can get is like a .600 lift cam....Yet the new Chevy 632 crate engine has a .780 hydraulic roller.....I keep going back to that engine, because it checks ALL the boxes of what I want in a Hemi....How do they get away with that, and how could I?
