Its not that mild....It still has a bit of duration and .700 lift at the valve....Just has a different ramp rate for drag and drive events. So -.050" lift and same duration...As I was hoping to lose as little HP as possible. Or switch to 572 or bigger wedge engine over a Hemi...My spray bars should work though. We are going to test them on the bench soon.
