Re: Stealth Heads, Max Wedge vs Std Port
[Re: gch]
#3120891
02/12/23 12:43 PM
02/12/23 12:43 PM
Posts: 14,514 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Ootb Stealths Flow right around 260 on my bench.
Recut the seats, back cut the valves, blend the bowls and SSR, they’re basically right at 280.
Whittle down the guide boss, open the pinch a bit, relieve the chamber wall adjacent to the intake valve....... puts it right at about 290.
I suspect that from that point, increasing the size of the opening to MW size would be worth less than 10cfm.
The set from the pic below went on a build that was going to be using a factory x-ram.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
Entire Thread
Mike@440Source
01/26/23 01:19 AM
Jeremiah
01/26/23 03:18 AM
Mike@440Source
01/26/23 05:52 PM
Mike@440Source
01/27/23 05:37 PM
Jeremiah
01/29/23 12:08 PM
rumblefish72
01/26/23 04:25 AM
AndyF
01/26/23 05:13 AM
Jeremiah
01/27/23 03:49 AM
AndyF
01/27/23 05:22 AM
CSK
01/26/23 05:26 AM
rickseeman
01/26/23 02:36 PM
69dart
01/26/23 02:41 PM
Dragula
01/26/23 03:49 PM
Mike@440Source
01/26/23 08:08 PM
Mike@440Source
01/26/23 08:55 PM
GY3
01/26/23 10:16 PM
Al_Alguire
01/27/23 04:40 PM
GY3
01/27/23 04:45 PM
Jeremiah
01/29/23 12:11 PM
MoParFish
01/26/23 05:18 PM
KOS
02/04/23 09:35 PM
Mike@440Source
02/07/23 10:12 PM
sixpakdodge
02/08/23 12:40 PM
Streetwize
02/08/23 04:32 PM
CSK
02/08/23 07:30 PM
HotRodDave
02/10/23 07:35 PM
Dragula
02/10/23 08:20 PM
AndyF
02/10/23 09:06 PM
GY3
02/10/23 11:32 PM
AndyF
02/10/23 11:36 PM
GY3
02/11/23 01:42 PM
StealthWedge67
02/11/23 05:56 PM
GTX MATT
02/11/23 09:53 PM
HotRodDave
02/11/23 10:13 PM
pittsburghracer
02/11/23 10:27 PM
FastmOp
02/11/23 11:04 PM
mxbeep
02/12/23 12:33 AM
gch
02/12/23 04:24 PM
fast68plymouth
02/12/23 04:43 PM
pittsburghracer
02/12/23 04:56 PM
GPSflyer
02/14/23 05:39 AM
GPSflyer
02/14/23 05:45 AM
powertrip
02/14/23 08:54 PM
GPSflyer
02/14/23 09:33 PM
A727Tflite
02/14/23 10:28 PM
GPSflyer
02/14/23 10:41 PM
A727Tflite
02/14/23 11:10 PM
GPSflyer
02/14/23 11:26 PM
A727Tflite
02/15/23 01:24 AM
GPSflyer
02/15/23 03:25 AM
A727Tflite
02/15/23 04:01 AM
Jeremiah
02/16/23 10:13 AM
GY3
02/14/23 10:27 PM
TonyS451
02/15/23 02:31 PM
BSB67
02/16/23 12:13 AM
fast68plymouth
02/16/23 02:49 PM
BSB67
02/17/23 12:15 AM
BSB67
02/08/23 11:16 PM
fast68plymouth
02/09/23 03:24 PM
Streetwize
02/09/23 03:44 PM
Cab_Burge
02/09/23 11:39 PM
Mike@440Source
02/18/23 02:33 AM
Mike@440Source
02/18/23 10:43 PM
Mike@440Source
02/18/23 02:20 AM
A727Tflite
02/18/23 08:09 AM
