Re: Stealth Heads, Max Wedge vs Std Port
[Re: HotRodDave]
#3120732
02/11/23 05:53 PM
02/11/23 05:53 PM
Posts: 5,169 CT
GTX MATT
CT
Just as with original max wedges, I'm sure the narrowing and rather severe port window angle is no doubt better than a standard port.....but is still limited by the lack of the raised roof and floor and the limited cross section due to the standard spring pocket and rocker arm geometry. This makes the transition to the bowl a pinch point.....but I suppose the MW logically increases the intake plenum volume and "charge" filling (or pushing through) the hole.
I always wondered where the crossover point between a low port Max wedge and say a raised standard window port like a TF 240 really shows up for a typical 550-650HP 500" combo.
It's a case where dry flow on a bench might show similar flow numbers....but in reality we know the suspended fuel doesn't 'turn' as easily as the air.
The stealth heads still look to be a great bargain, particularly when OEM sleeper appearance is a priority. 255 is a pretty decent port cc especially compared to a 906/452 port
I honestly don't know why anyone would bother with a standard port, they are barely higher performance than a comparable SB head. A 906 barely outflows an X head, raw stealth barely out performs a raw eddy SBM head. Something with 440 CID deserves a MW size port even in a very mild application. If it don't make good TQ something else is wrong beside the port volume. Heck a 392 genIII hemi has bigger ports and they make plenty of TQ in grocery getters. People are scared they will loose torque, then wonder why they can’t make more HP, give up and build a BBC with rectangular ports…
Now I need to pin those needles, got to feel that heat Hear my motor screamin while I'm tearin up the street
Entire Thread
Mike@440Source
01/26/23 01:19 AM
Jeremiah
01/26/23 03:18 AM
Mike@440Source
01/26/23 05:52 PM
Mike@440Source
01/27/23 05:37 PM
Jeremiah
01/29/23 12:08 PM
rumblefish72
01/26/23 04:25 AM
AndyF
01/26/23 05:13 AM
Jeremiah
01/27/23 03:49 AM
AndyF
01/27/23 05:22 AM
CSK
01/26/23 05:26 AM
rickseeman
01/26/23 02:36 PM
69dart
01/26/23 02:41 PM
Dragula
01/26/23 03:49 PM
Mike@440Source
01/26/23 08:08 PM
Mike@440Source
01/26/23 08:55 PM
GY3
01/26/23 10:16 PM
Al_Alguire
01/27/23 04:40 PM
GY3
01/27/23 04:45 PM
Jeremiah
01/29/23 12:11 PM
MoParFish
01/26/23 05:18 PM
KOS
02/04/23 09:35 PM
Mike@440Source
02/07/23 10:12 PM
sixpakdodge
02/08/23 12:40 PM
Streetwize
02/08/23 04:32 PM
CSK
02/08/23 07:30 PM
HotRodDave
02/10/23 07:35 PM
Dragula
02/10/23 08:20 PM
AndyF
02/10/23 09:06 PM
GY3
02/10/23 11:32 PM
AndyF
02/10/23 11:36 PM
GY3
02/11/23 01:42 PM
StealthWedge67
02/11/23 05:56 PM
GTX MATT
02/11/23 09:53 PM
HotRodDave
02/11/23 10:13 PM
pittsburghracer
02/11/23 10:27 PM
FastmOp
02/11/23 11:04 PM
mxbeep
02/12/23 12:33 AM
gch
02/12/23 04:24 PM
fast68plymouth
02/12/23 04:43 PM
pittsburghracer
02/12/23 04:56 PM
GPSflyer
02/14/23 05:39 AM
GPSflyer
02/14/23 05:45 AM
powertrip
02/14/23 08:54 PM
GPSflyer
02/14/23 09:33 PM
A727Tflite
02/14/23 10:28 PM
GPSflyer
02/14/23 10:41 PM
A727Tflite
02/14/23 11:10 PM
GPSflyer
02/14/23 11:26 PM
A727Tflite
02/15/23 01:24 AM
GPSflyer
02/15/23 03:25 AM
A727Tflite
02/15/23 04:01 AM
Jeremiah
02/16/23 10:13 AM
GY3
02/14/23 10:27 PM
TonyS451
02/15/23 02:31 PM
BSB67
02/16/23 12:13 AM
fast68plymouth
02/16/23 02:49 PM
BSB67
02/17/23 12:15 AM
BSB67
02/08/23 11:16 PM
fast68plymouth
02/09/23 03:24 PM
Streetwize
02/09/23 03:44 PM
Cab_Burge
02/09/23 11:39 PM
Mike@440Source
02/18/23 02:33 AM
Mike@440Source
02/18/23 10:43 PM
Mike@440Source
02/18/23 02:20 AM
A727Tflite
02/18/23 08:09 AM
