Awesome car, who makes a reasonably priced mopar to 4l80e bellhousing?
Thank you. I think ATI has an adapter for the bellhousing, but all I need is the adapter/spacer for the crank and the correct flexplate. My BMP block has a dual bellhousing pattern (GM/Chrysler) so the 4L80E will bolt right up. All I have to do is get lucky and find one at Pick n Pull or Craigslist.
