I did not see the two per side required felt donuts to go under the glass bolts for sale anywhere, so just fabricated the donuts out of some sheet foam I already had on hand.
There are 2 rubber washers and a rubber sleeve on each glass to regulator frame bolts. The sleeve can be made from vacuum line that fits over the bolt. I would not use foam.
