coolieo! New ones from Hughes are $300 bucks, and while that isn't a '
huge' amount...if the lifters pass my inspection (and I am pretty picky) I'll re-use 'em.
The 360 is going in the 02 Dak in my sig. All electronics have been removed, installing Eddy 7577 intake and Sniper 2bbl with HyperSpark ignition. Being build for overlanding including lots of technical rock crawling involving lots of just-off-idle running all day long. Multiple crawl ratios up to 134-1, and a 46rh for nice highway manners. Need a cam that has z-e-r-o lope, but has better mid range and top end - looking for better gains between idle-4500 rpm, cruising at ~2000 rpm. Any cam recommendations from the four listed above I'm all eyes.
Thanks for all the replies folks - much appreciated
Happy Holidays,
- Sam
