I haven’t had that problem but, I had a ProGear vibration big time on decelerating. I called Mark Williams, and after listening to the fault description, he asked if the pattern looked like a “flying v”. Indeed it did, and he told me to disregard the pattern, as the teeth move, depending on loads. I didn’t feel comfortable with the decel vibration, and installed a new gear set. FYI only.
