Originally Posted by Blusmbl
Originally Posted by JERICOGTX
At this point, I just want to get the engine together, dyno test it, and get everything in the car before the snow flies.
The wrong filler rod is a kick in the shorts on top of everything else, ugh.
If you get it together after the MN tracks are closed, would you head south with it to make some passes?
It’s costly enough to hit the local 1/8th mile track, 50 miles away. No way I’m headed South to test.
69 GTX 68 Road Runner
