I picked up my new engine build from the machinist today. Time to get busy, and bolt everything together.
Here are the specs of the build:
INDY RB Aluminum block
Molnar 4.375 crank
Molnar 7.100 rods
Diamond pistons 4.524 bore
INDY 440-1 345CNC heads, finished by Dwayne Porter. Flow numbers attached.
Compression ratio is 13.5:1
T&D 1.6 rockers
INDY 4403X intake manifold
Erson roller cam specs:
Lift Intake= .768 Exhaust= .760
Duration@ .050 =288/302
LSA= 111
Jesel belt drive
MSD Crank trigger
Moroso 4 vane vacuum pump
Thumper 1150cfm 4500 carb
Headers are 2.125-2.250 with 4” collectors.
I’m hoping to have everything together, and dyno test it in a few weeks. Anyone want to take a guess at what it will make for HP/TRQ?
Jeff
69 GTX 68 Road Runner
