Originally Posted by Al_Alguire
Best of luck hopefully it does all you want it to do.....Refresh my memory any big changes other than the block from the old set up?
The only thing I used from the old engine, is the distributor, and oil pan. SR heads vs 440-1 345CNC's, 499ci vs, 563ci, Bigger headers, bigger carb, and WAY bigger cam.
69 GTX 68 Road Runner
