Re: ATF favorite type brand , does it matter ?
[Re: n20mstr]
#3056281
07/05/22 01:45 PM
07/05/22 01:45 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I've always run Type F. No particular brand preference, just whatever I can find at the parts store when I need it. No issues w/ anything fluid related in a 3800 lb street driven car that runs 8s...w/ a 727. My trans/converter builder is local to me and is an ex super stock racer. He and his son ran 2 NHRA SS class cars up until 7 or 8 years ago I believe. He's been doing this a LONG time...he's one to listen to in my opinion. He told me years ago to run 1 quart of a synthetic Dexron V fluid for added lubricity and then fill the rest w/ Type F. This was after seeing some wear on one or more thrust washers if I recall correctly. He tells his customers NOT to run the JD Hygard fluid in their cars. If they need the stall tightened up, take it out and let him adjust it. He said the lubrication properties of it just aren't that good. I didn't ask him to go into any detail, that's just what he told me when I asked about using that fluid. He said it's fine to use as a test to see if tighter is faster, but not to use it long term. Interesting to hear this, according to rossler, the break for type F is at 1500hp, then its a mix of type F and hyd fluid. above 1500 its straight HYD fluid with maybe one qt of type F for color only to see on the stick. BUT maybe they think these kind of cars change it a lot more often??? Any way, i buy whatever type F is cheapest, and whatever hyd fluid is cheap and then mix them 50/50 Tony, that was my thinking also. At big HP levels, the fluid is gonna get changed often. How many passes does a 1500+ hp car get on a trans before something gets changed/fixed resulting in the fluid getting replaced? I bet it's not very many.
Entire Thread
bigdad
07/03/22 07:00 PM
John_Kunkel
07/03/22 07:59 PM
CSK
07/03/22 08:08 PM
6PakBee
07/04/22 12:56 PM
'72CudaRacer
07/04/22 03:18 PM
6PakBee
07/04/22 07:04 PM
W.I.N. Racing
07/03/22 11:10 PM
sr4440
07/04/22 01:18 AM
GY3
07/04/22 02:57 AM
pittsburghracer
07/04/22 03:01 AM
racerx
07/04/22 03:00 PM
Al_Alguire
07/04/22 06:52 PM
Brad_Haak
07/04/22 07:08 PM
Brad_Haak
07/04/22 07:16 PM
J_BODY
07/04/22 08:06 PM
Al_Alguire
07/04/22 10:13 PM
gregsdart
07/05/22 01:56 AM
Cab_Burge
07/05/22 02:14 AM
pittsburghracer
07/05/22 03:35 AM
CMcAllister
07/05/22 07:08 AM
11secdart
07/05/22 11:58 AM
moparacer
07/05/22 12:19 PM
Pacnorthcuda
07/05/22 03:35 PM
Brad_Haak
07/05/22 03:44 PM
GomangoCuda
07/05/22 03:49 PM
an8sec70cuda
07/05/22 04:14 PM
DoubleD
07/05/22 04:42 PM
n20mstr
07/05/22 05:26 PM
an8sec70cuda
07/05/22 05:45 PM
EvilB1Dart
07/05/22 06:47 PM
Blusmbl
07/05/22 07:33 PM
Sammy
07/06/22 10:05 AM
birdtracker
07/04/22 08:40 PM
EvilB1Dart
07/04/22 09:02 PM
Cab_Burge
07/04/22 09:49 PM
GY3
07/04/22 06:19 PM
Bad340fish
07/04/22 11:39 AM
Diplomat360
07/04/22 02:14 PM
GomangoCuda
07/04/22 02:55 PM
Brad_Haak
07/04/22 03:18 PM
CMcAllister
07/04/22 04:31 PM
Tig
07/04/22 05:18 PM
CMcAllister
07/04/22 05:30 PM
451Mopar
07/05/22 01:54 PM
racerx
07/05/22 03:36 PM
