Re: engine overheats, upper radiator hose cold, thermostat works
[Re: Bob Stinson]
#3054180
06/28/22 06:48 PM
06/28/22 06:48 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Just fixed a 440 that had a marine impeller on the water pump. The impeller was made to spin backwards. Double check the direction its facing. Here's a reverse one! FWIW I put a Milodon HV pump on my car recently and it's reversed compared to the one I took off. I then compared the one I took off to two other old ones I had and they are all oriented the same way. The Milodon part number was clearly marked for CW rotation. I got it from Mancini. https://www.manciniracing.com/brbhigvolwat.html Both of those pumps have the impeller blades at 90° to the centerline of the shaft. They would both perform equally whatever direction they spin. The orientation of the arms holding the impeller blades is irrelevant.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Entire Thread
Exit1965
06/20/22 02:55 AM
topside
06/20/22 03:18 AM
Exit1965
06/20/22 03:26 AM
MoparMike1974
06/20/22 05:14 AM
Sniper
06/20/22 11:45 AM
Exit1965
06/20/22 12:55 PM
Sniper
06/20/22 04:14 PM
TJP
06/20/22 05:51 PM
dssaa
06/20/22 10:27 PM
Sunroofcuda
06/21/22 03:32 AM
Moparite
06/21/22 10:24 AM
Mopar Mitch
06/21/22 07:41 PM
Sniper
06/21/22 08:47 PM
Mopar Mitch
06/22/22 09:34 PM
440_Offroader
06/23/22 02:44 AM
fast68plymouth
06/23/22 04:12 PM
Exit1965
06/23/22 04:21 PM
VL21
06/25/22 10:48 PM
Exit1965
06/26/22 08:14 PM
Cab_Burge
06/26/22 11:40 PM
TJP
06/28/22 04:12 PM
justinp61
06/20/22 12:42 PM
Cab_Burge
06/22/22 12:02 AM
A727Tflite
06/22/22 12:19 AM
TJP
06/22/22 01:45 AM
A727Tflite
06/22/22 02:08 AM
TJP
06/22/22 02:42 AM
A727Tflite
06/22/22 02:04 PM
R/T1968R/T
06/22/22 03:35 PM
cudaman1969
06/22/22 04:07 PM
R/T1968R/T
06/22/22 04:36 PM
NITROUSN
06/22/22 06:06 PM
Bob Stinson
06/28/22 02:02 PM
Hemi_Joel
06/28/22 10:48 PM
Bob Stinson
06/29/22 01:20 PM
R/T1968R/T
06/30/22 12:02 PM
Sniper
06/30/22 02:16 PM
second 70
06/22/22 03:36 PM
