engine overheats, upper radiator hose cold, thermostat works
#3051862
06/19/22 10:55 PM
06/19/22 10:55 PM
Posts: 3,377 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
Trying to track down a recent (didn't change anything) overheating problem on my 73 d200 with a 360.
When I start the engine from cold, it gets up to about 230 after roughly 6 minutes of idling or low rpm in park before I turned it off. The upper radiator hose never warmed up in that period of time. I took the thermostat out to test (and it was in plenty of water in the thermostat housing), and it's opening at 180 when I test it in a pan of water. The radiator is full, and I don't see any leaks. The thermostat, upper and lower radiator hoses are all fairly new (1-2 years), and it had always been running at normal (180ish) temperatures before the past couple of times I've driven it.
Does that indicate the water pump itself is bad? It seems like it's not pumping otherwise I think the upper hose would get hot at 180+ degrees (certainly by 220+), yet when I think of a "bad water pump" I usually think of leaking which I don't think it is.
Entire Thread
Exit1965
06/20/22 02:55 AM
Re: engine overheats, upper radiator hose cold, thermostat works
topside
06/20/22 03:18 AM
Exit1965
06/20/22 03:26 AM
MoparMike1974
06/20/22 05:14 AM
Sniper
06/20/22 11:45 AM
Exit1965
06/20/22 12:55 PM
Sniper
06/20/22 04:14 PM
TJP
06/20/22 05:51 PM
dssaa
06/20/22 10:27 PM
Sunroofcuda
06/21/22 03:32 AM
Moparite
06/21/22 10:24 AM
Mopar Mitch
06/21/22 07:41 PM
Sniper
06/21/22 08:47 PM
Mopar Mitch
06/22/22 09:34 PM
440_Offroader
06/23/22 02:44 AM
fast68plymouth
06/23/22 04:12 PM
Exit1965
06/23/22 04:21 PM
VL21
06/25/22 10:48 PM
Exit1965
06/26/22 08:14 PM
Cab_Burge
06/26/22 11:40 PM
TJP
06/28/22 04:12 PM
justinp61
06/20/22 12:42 PM
Cab_Burge
06/22/22 12:02 AM
A727Tflite
06/22/22 12:19 AM
TJP
06/22/22 01:45 AM
A727Tflite
06/22/22 02:08 AM
TJP
06/22/22 02:42 AM
A727Tflite
06/22/22 02:04 PM
R/T1968R/T
06/22/22 03:35 PM
cudaman1969
06/22/22 04:07 PM
R/T1968R/T
06/22/22 04:36 PM
NITROUSN
06/22/22 06:06 PM
Bob Stinson
06/28/22 02:02 PM
Hemi_Joel
06/28/22 10:48 PM
Bob Stinson
06/29/22 01:20 PM
R/T1968R/T
06/30/22 12:02 PM
Sniper
06/30/22 02:16 PM
second 70
06/22/22 03:36 PM
