Re: engine overheats, upper radiator hose cold, thermostat works
[Re: Exit1965]
#3051968
06/20/22 12:14 PM
06/20/22 12:14 PM
Posts: 6,258 nowhere
Sniper
nowhere
Not collapsing the bottom hose as far as I can see.
The 230 is from the digital water temp gauge. In 90 degree f weather, it seems it would be unusual to run an engine for 5-7 minutes without reaching 180. At which point hot liquid should begin to flow into the upper radiator hose as long as the thermostat is working, which it is. I think that's why I'm not believing it's just a bad temperature reading.
Gauge senders go bad. I would verify the readings with an IR gun or similar. Harbor Freight has them for cheap. Did you run it up to temp with the cap off an observe any water flow thru the radiator? Can you try this without a thermometer installed, to eliminate it?
Entire Thread
Exit1965
06/20/22 02:55 AM
topside
06/20/22 03:18 AM
Exit1965
06/20/22 03:26 AM
MoparMike1974
06/20/22 05:14 AM
Sniper
06/20/22 11:45 AM
Exit1965
06/20/22 12:55 PM
Sniper
06/20/22 04:14 PM
TJP
06/20/22 05:51 PM
dssaa
06/20/22 10:27 PM
Sunroofcuda
06/21/22 03:32 AM
Moparite
06/21/22 10:24 AM
Mopar Mitch
06/21/22 07:41 PM
Sniper
06/21/22 08:47 PM
Mopar Mitch
06/22/22 09:34 PM
440_Offroader
06/23/22 02:44 AM
fast68plymouth
06/23/22 04:12 PM
Exit1965
06/23/22 04:21 PM
VL21
06/25/22 10:48 PM
Exit1965
06/26/22 08:14 PM
Cab_Burge
06/26/22 11:40 PM
TJP
06/28/22 04:12 PM
justinp61
06/20/22 12:42 PM
Cab_Burge
06/22/22 12:02 AM
A727Tflite
06/22/22 12:19 AM
TJP
06/22/22 01:45 AM
A727Tflite
06/22/22 02:08 AM
TJP
06/22/22 02:42 AM
A727Tflite
06/22/22 02:04 PM
R/T1968R/T
06/22/22 03:35 PM
cudaman1969
06/22/22 04:07 PM
R/T1968R/T
06/22/22 04:36 PM
NITROUSN
06/22/22 06:06 PM
Bob Stinson
06/28/22 02:02 PM
Hemi_Joel
06/28/22 10:48 PM
Bob Stinson
06/29/22 01:20 PM
R/T1968R/T
06/30/22 12:02 PM
Sniper
06/30/22 02:16 PM
second 70
06/22/22 03:36 PM
