Re: engine overheats, upper radiator hose cold, thermostat works
[Re: Exit1965]
#3051996
06/20/22 01:51 PM
06/20/22 01:51 PM
Posts: 15,372 Omaha Ne
TJP
Omaha Ne
It's a direct drive fan. I didn't try a wobble check but will try that. There is some kinda rotational noise now that you mention it, though it's subtle and I haven't tried to pinpoint it. There is no heater on the truck anymore, so that outlet on the water pump is capped.
Thanks for the ideas. I'll see what it does without the thermostat in it tomorrow. Would I expect to see lots of activity in there if the pump was working OK? You should see the same activity with the stat open and the engine at 2K or more RPM. If not I would suspect a slipping belt, Impeller not turning, (off the shaft, loose on the shaft or broken shaft) or a blockage. keep in mind the blockage can be a plugged radiator, collapsing lower hose, T'stat not opening or installed upside down. Something is keeping the water from flowing, the question is WHAT ? Keep us posted
Entire Thread
Exit1965
06/20/22 02:55 AM
topside
06/20/22 03:18 AM
Exit1965
06/20/22 03:26 AM
MoparMike1974
06/20/22 05:14 AM
Sniper
06/20/22 11:45 AM
Exit1965
06/20/22 12:55 PM
Sniper
06/20/22 04:14 PM
TJP
06/20/22 05:51 PM
dssaa
06/20/22 10:27 PM
Sunroofcuda
06/21/22 03:32 AM
Moparite
06/21/22 10:24 AM
Mopar Mitch
06/21/22 07:41 PM
Sniper
06/21/22 08:47 PM
Mopar Mitch
06/22/22 09:34 PM
440_Offroader
06/23/22 02:44 AM
fast68plymouth
06/23/22 04:12 PM
Exit1965
06/23/22 04:21 PM
VL21
06/25/22 10:48 PM
Exit1965
06/26/22 08:14 PM
Cab_Burge
06/26/22 11:40 PM
TJP
06/28/22 04:12 PM
justinp61
06/20/22 12:42 PM
Cab_Burge
06/22/22 12:02 AM
A727Tflite
06/22/22 12:19 AM
TJP
06/22/22 01:45 AM
A727Tflite
06/22/22 02:08 AM
TJP
06/22/22 02:42 AM
A727Tflite
06/22/22 02:04 PM
R/T1968R/T
06/22/22 03:35 PM
cudaman1969
06/22/22 04:07 PM
R/T1968R/T
06/22/22 04:36 PM
NITROUSN
06/22/22 06:06 PM
Bob Stinson
06/28/22 02:02 PM
Hemi_Joel
06/28/22 10:48 PM
Bob Stinson
06/29/22 01:20 PM
R/T1968R/T
06/30/22 12:02 PM
Sniper
06/30/22 02:16 PM
second 70
06/22/22 03:36 PM
