Re: engine overheats, upper radiator hose cold, thermostat works
[Re: Exit1965]
#3051865
06/19/22 11:18 PM
06/19/22 11:18 PM
Posts: 20,787 A collage of whims
topside
A collage of whims
Test: leave the t-stat out, fire up, see if water in radiator is flowing or static. I'll assume static check of fan wobbling shows none, and no noise from water pump indicating breakage. Fan clutch ? Direct drive fan ? If no circulation, there's either a blockage or the pump isn't working. Blockage could be anywhere in the system (upper or lower hose, pump, housing, block, heads. Do you get any heat out of the heater ? (Not that it could cause that problem, but it'll be a secondary symptom.)
Entire Thread
Exit1965
06/20/22 02:55 AM
topside
06/20/22 03:18 AM
Exit1965
06/20/22 03:26 AM
MoparMike1974
06/20/22 05:14 AM
Sniper
06/20/22 11:45 AM
Exit1965
06/20/22 12:55 PM
Sniper
06/20/22 04:14 PM
TJP
06/20/22 05:51 PM
dssaa
06/20/22 10:27 PM
Sunroofcuda
06/21/22 03:32 AM
Moparite
06/21/22 10:24 AM
Mopar Mitch
06/21/22 07:41 PM
Sniper
06/21/22 08:47 PM
Mopar Mitch
06/22/22 09:34 PM
440_Offroader
06/23/22 02:44 AM
fast68plymouth
06/23/22 04:12 PM
Exit1965
06/23/22 04:21 PM
VL21
06/25/22 10:48 PM
Exit1965
06/26/22 08:14 PM
Cab_Burge
06/26/22 11:40 PM
TJP
06/28/22 04:12 PM
justinp61
06/20/22 12:42 PM
Cab_Burge
06/22/22 12:02 AM
A727Tflite
06/22/22 12:19 AM
TJP
06/22/22 01:45 AM
A727Tflite
06/22/22 02:08 AM
TJP
06/22/22 02:42 AM
A727Tflite
06/22/22 02:04 PM
R/T1968R/T
06/22/22 03:35 PM
cudaman1969
06/22/22 04:07 PM
R/T1968R/T
06/22/22 04:36 PM
NITROUSN
06/22/22 06:06 PM
Bob Stinson
06/28/22 02:02 PM
Hemi_Joel
06/28/22 10:48 PM
Bob Stinson
06/29/22 01:20 PM
R/T1968R/T
06/30/22 12:02 PM
Sniper
06/30/22 02:16 PM
second 70
06/22/22 03:36 PM
