Was that the member who had the dogs in Washington States car {Tom}?
Also while posting here is some pictures for size reference to a Mopar CA322 filter commonly used on 2x4 Hemi, Six Pack etc.
The last picture is measured from dead center to side. So width is twice that
I just got home from overseas and wanted to add some info... (Had to verify the air filter part number)
1) Yes, this is Tom's old Aussie Charger.
2) For this particular car I needed to trim the front and rear edges down to fit the shape of the hood so it would not rub.
3) I searched on-line quite a bit to find a filter element that would work, even had a guy at Carlisle show me what he was using. Anyway, what I ended up with was to buy 2 elements and make a small splice that added about 4-5 inches to the overall diameter and then shaped it to fit the form of the base. Fram air filter #CA3425 worked as it was the shortest height that still looked good. I just keep the splice at the rear and it is pretty much hidden from view.
4) I have no idea if Tom modified it or bought it that way but for sure a "normal" six pack assembly would never fit this car and not a fan of the three small round filters look.
