Re: Indy 3X , 550 cubes, gains from p porting the intake?
[Re: HardcoreB]
#2984447
11/12/21 11:20 AM
11/12/21 11:20 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
D Nice! Did he spec you Seat/Open valve loads? I told him what I was using and as I recall that was deamed ok. Due to economy I stayed with comp 947 triples on exhaust. Set at about 330 lbs on the seat. Intakes I had to go to PAC 1228 due to net lift of .848 after lash. Those ended up at 2.070 as I recall with about 310 lbs on the seat. The 1228 springs have a 2.100 spec installed hieght with 280 pds. At 2.070 they ended up at what I thought was enough since they have less mass than the 947s. The 2.070 is about max for -1 heads and I needed +.100 retainers and +.050 retainers combined with spring cups that are .030 thick.
Entire Thread
gregsdart
10/21/21 03:02 PM
JERICOGTX
10/21/21 03:26 PM
gregsdart
10/21/21 05:36 PM
HardcoreB
10/21/21 06:00 PM
Cab_Burge
10/21/21 06:00 PM
gregsdart
10/21/21 08:19 PM
AndyF
10/21/21 04:09 PM
Cab_Burge
10/21/21 05:14 PM
Dragula
10/21/21 07:14 PM
gregsdart
10/21/21 08:37 PM
HardcoreB
10/22/21 01:03 PM
gregsdart
10/22/21 02:02 PM
Cab_Burge
10/22/21 04:40 PM
440Jim
10/22/21 05:53 PM
gregsdart
10/24/21 02:13 AM
Cab_Burge
10/24/21 05:09 AM
Wicked49670dart
10/24/21 01:34 PM
fast68plymouth
10/24/21 03:36 PM
440Jim
10/24/21 03:45 PM
gregsdart
10/25/21 12:03 AM
gregsdart
10/25/21 10:53 PM
HardcoreB
10/26/21 12:25 PM
gregsdart
10/26/21 02:47 PM
JERICOGTX
10/26/21 07:05 PM
Al_Alguire
10/27/21 12:35 AM
AndyF
10/27/21 04:24 AM
Al_Alguire
10/27/21 04:46 PM
gregsdart
10/27/21 08:53 PM
Al_Alguire
10/27/21 09:21 PM
gregsdart
11/10/21 07:48 PM
HardcoreB
11/11/21 12:15 AM
gregsdart
11/12/21 11:14 AM
HardcoreB
11/12/21 01:12 PM
gregsdart
11/12/21 03:20 PM
440Jim
11/22/21 05:43 PM
Jeremiah
11/22/21 05:57 PM
440Jim
11/22/21 06:47 PM
AndyF
11/22/21 07:45 PM
gregsdart
11/21/21 01:34 AM
gregsdart
11/21/21 01:39 AM
AndyF
11/21/21 02:19 AM
gregsdart
11/21/21 04:07 AM
fast68plymouth
11/21/21 04:24 PM
gregsdart
11/21/21 11:04 PM
AndyF
11/21/21 11:56 PM
gregsdart
11/24/21 01:32 PM
madscientist
11/24/21 02:50 PM
gregsdart
11/27/21 03:10 AM
Cab_Burge
11/22/21 02:51 AM
gregsdart
11/22/21 03:08 AM
Cab_Burge
11/22/21 05:28 AM
440Jim
11/22/21 09:43 AM
HardcoreB
11/22/21 04:39 PM
440Jim
12/09/21 09:36 PM
gregsdart
12/10/21 03:18 AM
tboomer
12/10/21 11:52 AM
440Jim
12/10/21 12:49 PM
JERICOGTX
12/13/21 01:56 PM
HardcoreB
12/13/21 02:05 PM
