Originally Posted by Cab_Burge
looks like it wants to be shifted higher than you pulled it too work scope
1-2. At 7450 rpm, 2-3 at 7350 rpm. I tried higher and lower rpm, this was the sweet spot. Lag in the trans is worse on the 1-2 shift. Airshifter set at 7250. Next outing I will have seperate rpm settings for each shift.
