Putting disc brakes on the front. Well, some days you avoid the snowball, other days the snowball runs you over.
Going to have to take the uprights steering kniuckle to the machine shop to get new kingpins fitted up. Tie rod ends need replaced, steering box needs adjusting and if I am reading the date code correct I probably have the original hydraulic shocks.
Front shocks are damned expensive if you want stock hydraulic types. Pass. Did a bit of measuring adn found an alternate, 60-62 C10 front shocks will fit and work. Not to mention you can get good, gas charged ones for a reasonable rice.
All will be very nice upgrades.
DynoDave Walter P. Chrysler Club - Great Lakes Region Member # 12304 1970 Plymouth Duster 1972 Dodge Charger Rallye https://wichargerguy.proboards.com/ 1977 Chrysler Cordoba
