phasing is easy like check the rotation direction arrows on reluctor and set the pin guide to the dist shaft correctly.
Note about the gap... CHECK IT ALSO WITH VACUUM in PULLING position. Since ratious center of pick up and center of disttributor are TOTALLY DIFFERENT, then the circuference set by pick up never will meet the reluctor circunference. If you set the gap too close on rest positiomn, when vacuum is pulling in, the pick up will BITE THE RELUCTOR.
In my experience ( and I have tried everything bending here and there, milling here and there ) try to set the gap between 9-10 hundreds on rest position, and you'll get between 7-8 hundreds on vaccuum pulling position.
I definitelly set it on 9 to get 7
