292 296 ground on 113 with a .480 lobe. rockers are 1.75/1.55
Jesel TS center bar lifters. A solid body jesel would do the same job, I just had these on the shelf. The only real difference is the TS are a little lighter.
Just wanted to put this in this thread, for people that might think you need to break the bank to get decent power. The mopar struggle for power can be endless, and disproportionately expensive beyond point. Making reasonable power that will live, is better with a mope to a certain point too.
