That is my thought as well. Called up Best Machine in Detroit and spoke with Pete extensively about the build. I had him tag the BM Hemi block that’s on the way. I can drive down and pick it up when it’s done. Told him I plan on using Molnar crank and rods and suggest a Callies rod instead. Not sure which Callies rod, so what are you guys using?
