I did the rubber hose trick 2 months ago on the distributor to make it easier to set timing per BigCube and a couple others here. I'm starting to worry about the piece of rubber hose deteriorating in the motor. How long will it last before needing replaced? I was gonna check it tonite but it requires removing plug wires, 4 port regulator hoses, fan wires etc. I'm lazy.
