The rubber hose trick on the distributor
#29281
08/26/06 03:58 PM
08/26/06 03:58 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
I did the rubber hose trick 2 months ago on the distributor to make it easier to set timing per BigCube and a couple others here. I'm starting to worry about the piece of rubber hose deteriorating in the motor. How long will it last before needing replaced? I was gonna check it tonite but it requires removing plug wires, 4 port regulator hoses, fan wires etc. I'm lazy.
Re: The rubber hose trick on the distributor
[Re: ProSport]
#29283
08/26/06 04:22 PM
08/26/06 04:22 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I changed my hose for a 1/2" ID clamp collar. The hose felt a little spongy, but not falling apart. I would say check it and see how yours looks.
[Re: Bigcube]
#29284
08/26/06 04:32 PM
08/26/06 04:32 PM
Posts: 5,620 long island NY
Ari440
long island NY
where could one find a 1/2 id clamp collar at?
1.39 9.85 - 137 mph
[Re: Bigcube]
#29285
08/26/06 04:40 PM
08/26/06 04:40 PM
Posts: 3,441 Mo.
supercomp
Mo.
Post deleted by Defbob
[Re: CokeBottleKid]
#29287
08/26/06 05:14 PM
08/26/06 05:14 PM
#29288
08/26/06 05:17 PM
08/26/06 05:17 PM
Posts: 4,588 St. John's Newfoundland
440newport
I thought you were a Mechanical Engineering student... The clamp is positioned so there is near zero clearance between the bottom of the clamp and the top of the intermediate shaft gear. When the gear tries to ride up, it is stopped by the clamp.
Ah, that makes sense... I figured the slop was in the distributor shaft and not the oil pump drive, I could see the drive shaft trying to climb the gears like you say though..
[Re: SKR8PN]
#29292
08/26/06 11:24 PM
08/26/06 11:24 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
You can also get the 1/2" clamp at Graingers for $2.64 part # 1L660 To install it, put the clamp on the dist shaft, way down by the bottom. Tighten the clamp enuff that it won't fall off, but will still slide on the shaft. Install the dist and tighten it down. The installation will position the clamp for zero endplay on the dist shaft and intermediate shaft. Then remove the dist, tighten the clamp on the shaft so it won't slide, re-install the dist, and you are good to go.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#29293
08/26/06 11:25 PM
08/26/06 11:25 PM
[Re: blownzoom440]
#29295
08/27/06 12:02 AM
08/27/06 12:02 AM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
you should try taking the dist to a weld shop and put a weld down the end of the shaft and grind it to fit the gap.a weld shop would do it for free i bet being a small job he could tie in with another.
Why waste the time doing this ?...IF you do it this way and then at some point need to change the distributor or intermediate shaft you have to do it all over again.....with the collars....simply loosen the screws and place it on the new unit...simple..and easy.
#29297
08/27/06 05:53 AM
08/27/06 05:53 AM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
That's exactly how I did it! Great HEMI minds think alike.
ps: I used a drop of Loctite on the screws.
Dave, your hemi eyes must of missed that "trick" componet listed in the Hamburger 340/360 Catalog circa 1979, eh?
[Re: Leigh]
#29298
08/27/06 06:25 AM
08/27/06 06:25 AM
[Re: Blown71X]
#29299
08/27/06 08:02 AM
08/27/06 08:02 AM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
i would not think the parts would very that much to need adjusted every time you put a shaft or dist in.i dont ware my stuff out often enough to think about that i guess.the hose deal pushes my buttons for things not to do.sorry! i see the cost of the granger part is cheep enough to get that why bother.you would spend that much in gas getting it there.
[Re: blownzoom440]
#29300
08/27/06 09:45 AM
08/27/06 09:45 AM
ProSport
Akron, Ohio
Thanks for the awesome info as usual guys, time for a trip to Grainger this week!
