The only thing is see is that plate on the rad holding the fans. That’s not a shroud. I tried that same thing on my old demon, ran hot with 4 puller fans. An engineer friend told me I needed a minimum of 3/4” deep shroud. I believe that plate is restricting air flow.
Good eye! I went to check what I have and it's right about 3/4".
