Thank you for this info challengersteve! They did use urethane, I just don't remember in what spots.
Could you please tell me the exact order of the procedure, step by step?
This to body: Auto Bedding and Glazing Compound, 3M part number 08509. Install gasket, then put glass in, then Auto Bedding and Glazing Compound, 3M part number 08509 inside lock strip groove, and install lock strip? Is this correct order?
Thanks! Larry
Facts are stubborn things.
