The first KB street hemi block I assembled had the sleeves to high and I had to have KB fix them.
Make sure you get the specs. on the sleeve heights and check them as soon as you get the block scope correct if needed wrench
I had to get a special set of head gaskets made for that motor also due to it being a street Hemi block, not a race hemi block shruggy
Another reason you will see me call them Hemiriod motors whiney shruggy
