yes sir--thats whats in it--
i should be able to fine tone my dist when the kit arrives.
maybe my idle mix isnt as bad as i think.....i usually run the car in the garage...YES, the door is open.......
it wont idle unless i have both blades/idle screws at around 2-3 turns and the mix screws around 1.5 turns out.....
i think your exposing the transfer slot trying to raise your rpm when you shold use the dist.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
performance only racing, CRT, ultimate converter, superior design concepts, ThumperCarbs
