8082 is a 2 circuit
stock IAB is 71 and the high speed is 37
i think your tmming is to low.
my procedure is this, with carb off the car, i set throttle blades. install carb then set timming to desired idle rpm. if it wants 22* then i adjust dist to get the disired advance or lock it out. mine is basically at total at idle
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
performance only racing, CRT, ultimate converter, superior design concepts, ThumperCarbs
