Re: 511 tf270 cam, header, Intake, gear selection?
[Re: INTMD8]
#2842968
11/07/20 12:48 PM
11/07/20 12:48 PM
Posts: 2,141 junction city oregon
viperblue72
Next question. Do I have to worry about lifter coming out of bores too far and uncovering the oil band?
Yes, I measured this on mine. Many different lifter designs out there so that matters as well as the cam base circle. Based on the hyd flat tappet cam I had, discussed how much room I had to decrease the base circle with the cam grinder and how much room I had from there for lobe lift without uncovering the oil gallery. With an MP hemi block, unbushed, .430 intake lobe lift I'm only about .020 away on each end from uncovering the oil gallery. I’ll be at .412 lobe lift 🤞 Still, need to measure everything due to variance in lifter design and base circle. I do realize that I need to measure. I should of been clear. Thank you for the advice.
Entire Thread
viperblue72
11/04/20 05:34 PM
viperblue72
11/06/20 02:54 AM
Dragula
11/06/20 03:08 AM
viperblue72
11/06/20 03:40 AM
viperblue72
11/06/20 03:48 AM
tex013
11/06/20 04:26 AM
viperblue72
11/06/20 04:44 AM
tex013
11/06/20 05:35 AM
viperblue72
11/06/20 05:47 AM
tex013
11/06/20 09:20 AM
440Jim
11/06/20 06:48 PM
AndyF
11/06/20 07:53 PM
Dragula
11/06/20 08:02 PM
viperblue72
11/06/20 08:29 PM
Thumperdart
11/06/20 10:49 PM
INTMD8
11/07/20 04:22 AM
viperblue72
11/07/20 04:49 AM
INTMD8
11/07/20 05:12 AM
viperblue72
11/07/20 04:48 PM
viperblue72
11/06/20 08:30 PM
mopar dave
11/07/20 01:40 PM
PolyDart
11/07/20 02:52 PM
viperblue72
11/07/20 04:49 PM
PolyDart
11/07/20 09:46 PM
AndyF
11/07/20 10:56 PM
AndyF
11/07/20 04:50 PM
PolyDart
11/07/20 09:53 PM
Cab_Burge
11/08/20 01:44 AM
AndyF
11/07/20 04:51 PM
viperblue72
11/07/20 07:59 PM
viperblue72
11/07/20 08:02 PM
AndyF
11/07/20 08:14 PM
AndyF
11/07/20 08:13 PM
viperblue72
11/08/20 01:25 AM
PolyDart
11/07/20 09:58 PM
Cab_Burge
11/08/20 01:30 AM
PolyDart
11/08/20 01:46 AM
Cab_Burge
11/08/20 06:28 AM
PolyDart
11/08/20 03:24 PM
moparx
11/07/20 08:17 PM
AndyF
11/07/20 10:55 PM
Thumperdart
11/06/20 04:04 PM
viperblue72
11/06/20 06:04 PM
AndyF
11/06/20 06:22 PM
451Mopar
11/06/20 05:51 AM
viperblue72
11/06/20 06:24 AM
Cab_Burge
11/06/20 06:45 AM
viperblue72
11/06/20 07:14 AM
Cab_Burge
11/06/20 08:39 PM
viperblue72
11/07/20 01:22 AM
Uberpube
11/07/20 02:15 AM
viperblue72
11/07/20 04:50 AM
