Re: 511 tf270 cam, header, Intake, gear selection?
[Re: viperblue72]
#2842582
11/06/20 02:48 PM
11/06/20 02:48 PM
Posts: 16,930 NC
440Jim
NC
I want to make 700hp and a big torque curve. It’s 11 to 1. How would you do it w/solid roller? Intake? Headers? Can’t find a 2” but tti has 1 7/8 or 2” to 2 1/8 step. Cam? Duration and lift? I’d like to reach my goal and be as conservative as I can get away with. Where do I need peak power to be?
OK, the compression ratio and power expectation helps with cam selection, IMO. I don't have any TF combo to compare to, but this is my input. 511 CID with TF270 heads can make 700 hp pretty easily. I would prefer slightly over 11.0 CR, so if the final chamber size (milling heads?) and space above the piston (compression height and valve reliefs can get you closer to 11.5 CR; that would be nice. The header choice will have people liking both. But I say for mostly street and a 4-speed, go with the smaller headers; even though peak HP will be a little less. Cam duration between 265-270 degrees at 0.050" tappet lift. Valve lift with 1.5 rockers 0.620"-0.660". With the TF intake port exit slightly improved, I would expect peak power of my picks 6000-6200 rpm. Low end (2500-3500 rpm) torque will be better with the smaller headers so you won't have to down shift to the torque peak around 4900 rpm. Even with 11.0 CR, a 260-265 cam with 0.640" lift can make the 700 hp around 6000 rpm, torque peak around 4600 rpm. But if it only make 695 don't be mad.
Entire Thread
viperblue72
11/04/20 05:34 PM
viperblue72
11/06/20 02:54 AM
Dragula
11/06/20 03:08 AM
viperblue72
11/06/20 03:40 AM
viperblue72
11/06/20 03:48 AM
tex013
11/06/20 04:26 AM
viperblue72
11/06/20 04:44 AM
tex013
11/06/20 05:35 AM
viperblue72
11/06/20 05:47 AM
tex013
11/06/20 09:20 AM
440Jim
11/06/20 06:48 PM
AndyF
11/06/20 07:53 PM
Dragula
11/06/20 08:02 PM
viperblue72
11/06/20 08:29 PM
Thumperdart
11/06/20 10:49 PM
INTMD8
11/07/20 04:22 AM
viperblue72
11/07/20 04:49 AM
INTMD8
11/07/20 05:12 AM
viperblue72
11/07/20 04:48 PM
viperblue72
11/06/20 08:30 PM
mopar dave
11/07/20 01:40 PM
PolyDart
11/07/20 02:52 PM
viperblue72
11/07/20 04:49 PM
PolyDart
11/07/20 09:46 PM
AndyF
11/07/20 10:56 PM
AndyF
11/07/20 04:50 PM
PolyDart
11/07/20 09:53 PM
Cab_Burge
11/08/20 01:44 AM
AndyF
11/07/20 04:51 PM
viperblue72
11/07/20 07:59 PM
viperblue72
11/07/20 08:02 PM
AndyF
11/07/20 08:14 PM
AndyF
11/07/20 08:13 PM
viperblue72
11/08/20 01:25 AM
PolyDart
11/07/20 09:58 PM
Cab_Burge
11/08/20 01:30 AM
PolyDart
11/08/20 01:46 AM
Cab_Burge
11/08/20 06:28 AM
PolyDart
11/08/20 03:24 PM
moparx
11/07/20 08:17 PM
AndyF
11/07/20 10:55 PM
Thumperdart
11/06/20 04:04 PM
viperblue72
11/06/20 06:04 PM
AndyF
11/06/20 06:22 PM
451Mopar
11/06/20 05:51 AM
viperblue72
11/06/20 06:24 AM
Cab_Burge
11/06/20 06:45 AM
viperblue72
11/06/20 07:14 AM
Cab_Burge
11/06/20 08:39 PM
viperblue72
11/07/20 01:22 AM
Uberpube
11/07/20 02:15 AM
viperblue72
11/07/20 04:50 AM
