Originally Posted by AndyF
Originally Posted by carnut68
Originally Posted by fast68plymouth
If it’s a street/strip build, then I first look at how many miles per year it will get driven...... and then determine if going to a SR makes sense for how the car will be used.
Then, if it looks like the ST is a viable option........along with the particular cam profile, spring loads, and rocker ratio........ determine how good the lifters need to be based on usage, initial cost, and replacement/rebuild time intervals.
Low maintenance and pump gas are the main reasons i built another shortblock. Any 511 in an A body will be a handful.
If you want low maintenance then go with a hyd roller rather than a solid roller. You'll give up some power above 6000 rpm but you most likely aren't going to take a 511 in an A body to redline very often anyway. I run hyd rollers in both of my cars for the same reason.
The way the car is now it never sees the street. Its a 446 race gas only set up 590 cam so its not ideal for street driving. Best et 10.82 best mph 126.0.
America First!
