Originally Posted by moparjack44
I have A727TF (SB) hooked to 1st Gen 392 Hemi, useing Hot Heads adapter. The tranny/carb linkage is Lokar, connected to 2 500cfm edelbrock carbs. My kickdown does not kickdown. Keeping in mind, I am not a mechanic, just a tinkerer. Can someone simpify the adjustment for me. It's a 48 DeSoto hot rod, shifter on the column.
THANK YOU,
Jack
Never kicks down even at around 30 mph? NEVER
At light throttle what are your shift points from 1-2 and 2-3?
1ST to 2ND, about 10MPH........2ND to 3rd, between 15-20 MPH
Shifting that early sounds like you are not making enough throttle pressure. Lever is too far forward at any given point.
Like said earlier- check at WOT and see if the lever is almost all the way back.
Lastly, what axle ratio are you running? A high numerical axle ratio makes it even harder to get a downshift at “normal” speeds.
