I have A727TF (SB) hooked to 1st Gen 392 Hemi, useing Hot Heads adapter. The tranny/carb linkage is Lokar, connected to 2 500cfm edelbrock carbs. My kickdown does not kickdown. Keeping in mind, I am not a mechanic, just a tinkerer. Can someone simpify the adjustment for me. It's a 48 DeSoto hot rod, shifter on the column.
